Results 1 to 3 of 3
Thread: Pinion Markings
    Dec 2007
    Jim Thorpe PA
    Default Pinion Markings
    I'm putting a locker in the rear axle of my truck. When I pulled the differential out, I noticed there were some markings on the pinion gear, just wondered if anybody knew what they meant. It looks like they were hand engraved.
    I'm not too swift at picture taking, but the engravings are: "+3" at the top, "K" on the left hand side, "0" on the right, and "217" on the bottom.
    Wir müssen Leben bis wir sterben
    Nov 2008
    middlesex county ,CT
    Default +.003
    when using pinion depth gauge . This mean you add .003 to feeler gauge reading to set proper pinion depth. The inner bearing shim set up. If -3 you would reduce shim thicken by .003.
    Dec 2007
    Jim Thorpe PA
    Cool, thanks. I figured it had to do either with manufacturing the gear or setting it up. I've never done anything more than change out oil in axles before.
  1. Pinion seals
    By Hetzer in forum Stock Tech
    Last Post: October 5th, 2009, 09:53 PM
  2. pinion seal?
    By TWhetten in forum Stock Tech
    Last Post: January 5th, 2008, 12:17 PM
  3. Need a rear axle pinion nut.
    By TheWarTapes in forum Stock Tech
    Last Post: March 6th, 2007, 08:10 PM
  4. Ring+ Pinion?
    By poolmike in forum Modified Tech Archives
    Last Post: May 10th, 2004, 11:24 PM
  5. ring and pinion swap
    By bggrntrk in forum Modified Tech Archives
    Last Post: February 17th, 2004, 11:40 PM
