Results 1 to 10 of 15
Thread: lug wrench pic
    Default lug wrench pic
    can someone post a pic of an original lug wrench? I looked and could not find a pic.
    Duane
    Good luck with that...they are VERY rare.
    Quote Originally Posted by Duane View Post
    Duane
    Do you mean the L shaped tool, about 2ft long. This cant be that rare I wouldnt think.
    1968 M715
    1952 M38
    I have one, I can try to get a pic on saturday
    68 M-715 MVPA #2710
    great thanks
    Duane
    Port Orchard, Wash.
    Kwai would have had one to go with the even rarer (sp?!) jack, but the doof put it back in my truck and I didn't see it until I got to Utah.
    I can take a picture of it too if I don't see one posted this weekend.
    -- Tim Taylor
    Id love to see a pic of that too if anyone has one....
    The 715 lug wrench is actually the same as the civ version just w/ a larger lug socket end, it even retains the chisel end for hub cap removal. Its so long to alllow it to be used to lift the spare carrier up, however the military tire is so much heavier than a civ. one its almost impossible to use it that way.
    68 M-715 MVPA #2710
    Sep 2008
    Stevens Pointski, Wisconsin
    Can you measure the wrench, length of each side and the thickness, please. It looks easy enough to make these in my shop.
    Scott
    I am sure there will be enough people that would be intrested to make it worth your while. now we need that pic of the jack . another hens tooth to find I hear.
  1. Stock jack and lug wrench pics!
    By brute4c in forum Stock Tech
    Last Post: November 1st, 2018, 09:52 AM
  2. dxeflyr : Torque wrench question
    Last Post: November 11th, 2009, 12:23 AM
  3. stock spark plug wrench
    By militarytrux in forum Modified Tech
    Last Post: January 12th, 2009, 08:59 PM
  4. Brake adjustment wrench
    Last Post: August 19th, 2008, 11:44 AM
  5. a solution for the spark plug wrench
    By twostorms in forum Stock Tech
    Last Post: August 20th, 2007, 12:59 PM
