I want to know how well you like the conversion.
How is the power and how does it compare to a gas engine,like a small block chevy or ford?
I'm also interested in how well it would work for lite towing, under 8000 lbs?
Thanks Tom
Thanks Tom
My M715 (in construction) now has a 6BT, but I do have a '63 J300 with a 4BT, NV4500, NP200 and Dana 70/60 axles, so it is quite equivalent to a M715.
The engine is a CPL 858 4BT with the 3200 RPM spring, HY35, volvo intercooler and tweaked pump. The truck is a pleasure to drive and while it's not a hotrod, it has plenty of power. I haven't towed anything, but I've carried 2500lbs in the bed and the little 4BT just chugs along without any complaints. Mileage is typically 23-25MPG. My only complaint is the noise. The cab is completely uninsulated (I don't even have a carpet), so I think there is much room for improvement. Another thing I don't quite like is the gear spacing of the NV4500 (3-4 mainly), but it's a 5-speed wide ratio tranny.... Got to have big jumps somewhere.
Thanks for the reply. I know the 4BT is no hot rod.I just want to know if it can hold its own on the road.I would like to be able to hold 65 to 70 on the freeway and be able get out of it's own way.
I really like the milage your getting.Thats a dream with my pesent daily driver,a F350 crew cab 4x4 with a 5.8 gas 5spd/4.10 gears.
(I would love to be able to put a 6BT in my M715)
You would have had to have gotten the Powerstroke in that Ford to get close to that mileage. However, just like the 6BT won't get close to the fuel economy of the 4BT, the Powerstroke is similarly limited to about 19-20mpg with your specs. What kind of fuel economy do you get with that Ford gas motor?
One more question
How does the 4BT compare to the GM 6.2 ro 6.5 with a turbo??
I had a 1980 J10 I bought with a 6.2 NA in it. It was the worst motor I have ever had. I had a 4b put in and it was a world of difference in stock form. Then I started tuning the pump, injectors,etc. Now Im putting a 6n in a 715.
Power and Diesel I find addictive......you have been warned!
