Guys be very careful with the routing of the main power wire (black) that comes into the distributor. Mine got severed by the weights inside the distributor leaving me stranded at a busy intersection yesterday. A $50 tow later I got home and today discovered the problem.
97XJSP had the same problem and he solved it by taping the black wire to the coil. Thanks to a spare engine I swapped my wires assemblies out and it is currently not in contact but I think I will do the same thing as 97XJSP just to be on the safe side.
