Quick update. The driveline is largely in place. I still need to shim the various driveline components to make the u-joint angles match. The rear axle pads aren't welded, so I can rotate the pinion as needed.
I'm surprised how little effect flex has on the swivel driveshaft. I was expecting a much higher angle.
