Results 1 to 3 of 3
Thread: Separating flywheel from crank
    Springdale, Arkansas
    Default Separating flywheel from crank
    Well I have the crank/flywheel all marked, labeled (for reassembly) and ready to pull apart.
    I took all the nuts and locking washers off and pushed the studs back about an inch apiece. Now the two won't separate. I tried gently urging it with a rubber dead-blow hammer, tried rotating it just to break the tension...no-go.
    Any ideas?
    This must be a herculean (ooooo-good word) task with it still in the truck.
    You've got the bellhousing off before the flywheel? Maybe a photo would help.
    Apply heat.
