Page 4 of 17 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 168
Thread: 1967 Kaiser Jeep M-715 6BT Build
  1. #31
    More progress... got the 6BT, ZF, and NP205 all together for its first time mock in between the frame rails... (also did a bit of mock graphing the 67' NP200 parking brake onto the modern ford 32 spline NP205)
  2. #32
    ford 205,s are 31 spline, if you have 32 spline somebodys been changing up internals
  3. #33
    Quote Originally Posted by md1970 View Post
    We went thru this already... Ford inputs are 31 spline... All NP 205 outputs are 32 spline. All.
  4. #34
    Nov 2009
    Greenwood, Indiana
    Any updates?
    Thanks, George
    Joshua 24:15
  5. #35
    Yup... just nothing glamorous....
    Carefully removed and kept completely intact the OEM motor mounts....
    Not sure if anyone will EVER have a need for a nice set of OEM mounts... but I now have them.
  6. #36
    Sep 2014
    Wichita Falls, TX
    Quote Originally Posted by venominjected View Post
    Hmmm.. could mount them on the wall of your garage to hold.. something or other.
  7. #37
    you,d be surprised at the number of folk who will want them as theres have been butchered. there perfect for sbc conversions as well as stock.
  8. #38
    Feb 2007
    Bloomfield CT
    I have a good set of the motor mounts as well if someone needs them....
    Venom...I may look for some more info on that e-brake at some point, I have a disc brake 70hd rear that has a brake provision, but who doesn't love another working lever it the cab? I have a Dodge 205 to go in mine...
    Is that real money?
  9. #39
    Nov 2009
    Greenwood, Indiana
    Good deal, keep the pictures coming
    Thanks, George
    Joshua 24:15
  10. #40
    OEM M-715 NP200 t-case parking brake.... meet modern Ford NP205 married T-case..... now onto mounting the brake handle on the side of the 5 speed ZF....
