Page 12 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 111 to 120 of 168
Thread: 1967 Kaiser Jeep M-715 6BT Build
  1. #111
    Sep 2014
    Wichita Falls, TX
    Schweeeet.
  2. #112
    Looks like someone has been active ...
    I like how it is turning out.
    Any more details that you can share with the tank swap?
    Specifically what did you use for mounting it, what application
    was it from, and what did you use for the sending unit?
    How are you planning on routing the fill?
    Thanks
    Paul
    1967 M715 7.3 diesel 5spd ...
  3. #113
    Quote Originally Posted by 12998 View Post
    Thanks
    Paul
    The tank was purchased new and is for a 1985 Chevy K5 Blazer
    It is 26 gallon (there is also a 31 gallon option)
    I made a "cage" for it and suspended it under the frame rails...
    For a sending unit I am using the factory 1985 Chevy K5 Blazer with the 6.2L diesel option... this sending unit has a pickup and return line as well as a vent built in...
    The gauges I will be running in this truck can "select" which OHM setting is needed so i really dont care if its 0-90Ohm full or 30-240 etc. or 12 volts vs 24.
    For filling I pretty much plan on routing the fuel hose between the bed floor and above the frame rail as there is already a very large gap there.
    I may relocate the OEM fuel fill to behind the rear fenderwell instead of in front... or simply add another fuel door there. Unsure yet but I think I've seen both done on m715's before.
  4. #114
    WOW!!!!!!!!!!!
    Way to save a thread Sir!
    Hats off to ya both one the relinking AND the great build...something this good should NOT be lost ever!!!!
  5. #115
    Apr 2016
    Katy, TX
    Default Nice work!
    Inspiring work. Top notch. Thanks for sharing.
  6. #116
    Thanks for the tank info.
    Just ordered mine, pretty much going to copy what you did.
    Its going to be one of the winter projects.
    Paul
  7. #117
    Front Dana 60 Kingpin front axle replacement for the m715 (out of a 88' F350) complete... onto reinstall and begin wiring and brake lines.
    The day I found it :BEFORE:
    DURING:
    AFTERNew inner axle seals, new bearings, new hub seals, new U-joints, new calipers, new rotors, new kingpin bushings, new lockouts)
  8. #118
    Front Dana 60 now complete entirely(calipers and tie rod now on)...
    Cab back off for 4" exhaust and brakeline routing.
  9. #119
    Working on rear backup and bumper end markers
    2010 Duramax hydroboost final install with a new MC along with the hydraulic clutch master cylinder (new 90's Ford ZF5 master cylinder) along with hooked up to OEM pedals.
  10. #120
    Apr 2016
    Katy, TX
    Soooooo jealous. Amazing work and pics.
