Throttle cable will work...just reposition it..its kind of obvious when you get there...maybe I still have a pic...
I used a tee for the coolant line...thats pretty easy too...I have heard others drilled out and tapped the boss...it would be a cleaner install...
Choke cable was fine.
Air cleaner...you have a lot of choices...I went with one of the below...plenty of hood clearance AND plenty of air flow:
Its called: Pro-Flo 1000 Series Chrome Air Cleaner with Foam Element with 5-1/8" Air Horn
Let me look here and see if I still have pics of the installed linkage...
