Page 11 of 18 FirstFirst ... 23456789101112131415161718 LastLast
Results 101 to 110 of 175
Thread: M715 Finland
  1. #101
    A few photos of progress...
    All did not go as it should have been :/
    Need to re-weld ...
  2. #102
    Yes, it begins to take shape Is the steering axle rubber still available? Somewhere? Does anyone know..
  3. #103
    Hockey World Champion 2019 FINLAND
  4. #104
    Hallo M715 FIN,
    Timken is Timken, were ever you buy the bearings. The bearing numbers are allways the same. Radial seals are also standart, CR radial seals are awailable in Europe since SKF bought CR several years ago. Try to buy tese parts at an Industry part supplier. The Tie Rod End Cover are available at Surplus City Jeep Parts, 4514 Pacific Heigths RD, Oroville, CA 95965, US for something like 1,95$ one each (http://originalmilitaryjeepparts.com/m715/M715.htm).
    Greetings
    Wolf
    Since 1980 owner of a M715.
  5. #105
    Hello everybody. It has been a bit silent for this project. The problem was caused by an old invention. "MONEY". Every time you start repairing something ... Need to buy or order new parts: / I started to power the electricity ... Both of my light switches were broken, I split up both parts and were rusted completely, same was with windscreen wipers So now order more parts...
  6. #106
    Is the light switch same as m38a1?
  7. #107
    Quote Originally Posted by M715Fin View Post
    More or less yes. The three lever light switch is a mill standard part meaning the same part was used on M38A1, M151s, M35s, M49s, etc. Pick up any three lever light switch from the 60's to - just about present will work.
    Zone holster maker
  8. #108
    Silver Lake Sand Dunes MI
    Quote Originally Posted by k8icu View Post
    Yes, except that you have to watch out for the ones from the early 50's as they had two plugs instead of the large one. I believe they changed at the same time as the change from Douglas to Packard fittings.
    Dave
  9. #109
    Hello,
    Now I got a new light switch. Next, I'll ask you, what position the switch should work ... Headlights, parking light, which light is ser.light or B.O. drive etc? The reason why I ask you can see picture below. whiring was cut off when the car came to me. Are 1. the main power for the switches? 2. Disconnected cables for to tail lights? 3. Tail light wires
  10. #110
    I think 1 is the wires for the horn...3 is the wires that go to the rear harness to run the tail lights/turn signals/stop lights in the rear.
    The ones in 2 might be for the front lights but i cant tell from the pic...
    What do you have on the firewall for the light system...the large distribution box or the small solid state unit....or something else?
    Reference:
    Large distribution box:
    small solid state unit:
