Results 1 to 9 of 9
Thread: M715 Dimensions
    M715 Modeller Guest
    Default M715 Dimensions
    Sorry if this isn't the purpose of this part of the site, but I was wondering if I could get some dimensions of an M715 for a model building project.
    Here are the measurements I am looking for.
    -width of the cab
    -height of the cab, rocker panels to the top of the door
    -width to the outside of the fenders
    -width of the bottom of the windshield
    -height of the windshield
    -inner dimensions of the bed
    -outer dimensions of the bed, with the tailgate excluded from the length
    Hi, and welcome
    We would be happy to help out with your modeling project.
    I'm a life long modeler myself.
    Give me a day or two, and I will post the requested measurements.
    I can provide photos of any detail that you would like as well when needed.
    Dan
    What kind of model are you working on? RC?
    M715 Modeller Guest
    Yes, I'm working on some ideas for a new look for my rc crawler and a jeep truck is pretty high on the list.
    This set of files is $75, but might save you a ton of time when it came to measurements and reference??
    https://hum3d.com/3d-models/kaiser-jeep-m715-1967/
    Appears they bobbed the bed though...and the mirrors are wrong...but other than that...
    Here is the build thread...
    M715 Modeller Guest
    Thanks. I think I can get most of the proportions from pictures, just need some basic measurements to scale from.
    I apologize for the delay, been working overtime.
    I'm off this weekend, and will have time to measure.
    Moving this very interesting thread to Open Discussion Forum as it is not a website problem or comment but a technical discussion that belongs in a technical forum...carry on!
    OK, now that we are all on the correct page
    -Cab width at widest point is 72.25"
    -Cab height from top of rocker panels to top of cab pillar is 28" -add 3.50" for rocker panel height.
    -Windshield height at center is 21"
    -Windshield width is 60.5" at bottom (or 61" hinge to hinge).
    -Fenders at widest point 72.25" (same as cab), adding 4" for each flair makes it =80.25" outside edge of flairs.
    -Bed is 69.25" wide outside, adding 5.5" for each flair, makes it = 80.25" outside edge of flairs.
    -Bed inner width is 64"
    Bed box is 92.5" long inside, adding 1.5" for front bulkhead to give outside length.
    We expect pictures of your modeling project.
