Results 1 to 10 of 11
Thread: what's this steering joint?
    Question what's this steering joint?
    All, I can't figure out what joint this is called. It's on the steering shaft right after it exits the firewall. Mine is fubar'd (boot torn, grease everywhere) and I need a new one. I don't really want to replace the steering column but I'm not finding any options on google. So does anybody know the actual name of this joint and places that I can find it? Thanks for the help.
    @hayeselmotors
    Group 14 in the -34P TM. Called a coupling. Others call it a CV joint sometimes.
    Is that the joint called the rag joint? I am guessing the rag joint is probably lower down but you never know how trucks get modded over time...
    The rag joint is lower down as you suggested at the other end of the shaft. I think that these couplings may be somewhat standard. I was able to get new parts for mine several years ago but don’t remember where. I checked VPW but didn’t see this one. Not much help I know, sorry. When I get back to the I’ll see if I can find more info.
    Aug 2015
    Portlandia, Oregon USA
    Same as Don, I rebuilt mine with new steel squares, square holder clip thing-ee, a new outer circlip. fresh grease and rubber boot. Can't recall where I got the parts, but I know it was a mainstream place so they are likely still out there and not a lot of dough. There are a couple step by step tutorials on here (or maybe on youtube) about how to change those parts out.
    Also, you will likely find that your white plastic bushing at the end of the steering column is significantly worn as well (you can see it in the pic you posted). I think those are M715/725 specific- I think VPW or Memphis still have those.
    Bryce
    1969 M725 ambulance
    Thanks for the info all. I'll see if searching it as a coupling/CV joint works. yeah, that bushing may be bad. although, the truck allegedly only has ~20k miles on it
    @hayeselmotors
