Thread: Exterior door handle removal
    Nov 2009
    Greenwood, Indiana
    Default Exterior door handle removal
    I need to remove the handles to strip and repaint underneath.
    I haven’t gotten into the doors at all, are the handles hard to get off?
    Thanks, George
    Joshua 24:15
    Very easy. There is a bolt at each end. The thumb plunger part is just a rod behind the outer part you push. That rod pushes against the latch assembly and does not connect to it physically other than pushing against the latch release lever. You can take apart the handle and lightly lube everything and check the return spring. I think you can get the handle gaskets at BJ's offroad. Easy peasy...
    Liz, covid, murdered 10/19/21
    Nov 2009
    Greenwood, Indiana
    Quote Originally Posted by Kaiserjeeps View Post
    Awesome, thanks
    Thanks, George
    Joshua 24:15
    Nov 2009
    Greenwood, Indiana
    Digging into the doors tomorrow
    Thanks, George
    Joshua 24:15
    Nov 2009
    Greenwood, Indiana
    You were right on Kaiser. The handle was an easy one, and the plastic gasket disintegrated when I took the handle off.
    Pictures for those who may search this in the future:
    Thanks, George
    Joshua 24:15
    Silver Lake Sand Dunes MI
    As for the handle gaskets, BJ's Off-road has new ones for the civilian Jeep that are the same as the M715 https://bjsoffroad.com/door-handle-g...-lock-gaskets/
    Dave
    Nov 2009
    Greenwood, Indiana
    Quote Originally Posted by Beast View Post
    Thank Dave. Decals came today, thanks!
    Thanks, George
    Joshua 24:15
    Quote Originally Posted by Flingarrows View Post
    Awesome, enjoy them!
    Dave
