Results 1 to 2 of 2
Thread: 6bt engine mounts?
    Default 6bt engine mounts?
    anyone on here making 6bt conversion engine mounts or plans? Thanks!
    When I did it a while ago. The mounts were part of the "Hmm, how should this work?" fabrication process.
    If you are going to do a 6BT swap. I would recommend a gantry crane or something more substantial than a regular engine hoist to move the engine around and hold it for fitting. It is a very heavy engine assembly before you add in the clutch, transmission and accessories.
