Results 1 to 4 of 4
Thread: Military to Civvy tire sizes
    Default Military to Civvy tire sizes
    Anyone know what the civilian tire size equivalent of the military 9.00x16 tire is? What is standard 9.00x16 NDT tire diameter? Thanks,
    The formula for tire size is:
    (tread width x aspect ratio) x 2 + wheel diameter = tire diameter
    All crossply tires (such as 9.00x16) have a 100% aspect ratio.
    So (9.00" x 1.00) * 2 + 16" = 34" diameter
    An 11.00 x 16 would be (11" * 1.00) * 2 + 16 = 38" diameter
    A (325/75R16) would be 325 mm tread width, 75% aspect ratio and a 16" diameter. There are 25.4 mm per inch. So (325/25.4*0.75)*2 + 16 = 35.2" diameter. However, actual diameters are typically less than what is calculated.
    You can take it from here.
    Great info, thanks!
    A 315/85R/16 is real close...
  1. Civvy intake
    By Pineyguy in forum Modified Tech
    Last Post: November 12th, 2009, 07:19 AM
  2. How about a sticky to list thread sizes used?
    By 40Grit in forum Stock Tech
    Last Post: October 11th, 2007, 10:22 PM
  3. Tie rod and drag link ends sizes
    Last Post: February 13th, 2007, 04:24 AM
