Quote Originally Posted by Kaiserjeeps View Post
Well it went very well and no issues. I did warm the glass with a heat gun from a distance. Just in case.. The glass was undercut by quite a bit. So it went in pretty easy. I used silicone lube soaked into a blue shop towel and put it on the seal lockstrip and groove, I used two plastic trim prybars to work it in. The seal drank up the wiped silicone and there was zero clean up. I put the bottom in and worked up both sides. Then made my way around the top. Very glad to have that behind me. Thanks for the advice.
Glad it worked out for you. I can be very nerve racking to do.
