Results 1 to 5 of 5
Thread: Oil Pan Gasket
    Jan 2007
    Winona, MN.
    Default Oil Pan Gasket
    Hi All-I'm Terry from Winona,MN. First time caller. I just bought a '69 from TX. Seems to be in overall very good shape. It's an Ex-VFD truck. It is leaking oil from rear main on the 230. I have found a crank seal locally but did not show listing for a pan gasket. Is there one available or will an RTV product work? Thanks
    Try Surplus City Jeep Parts or Memphis Equipment Company. Also, believe it or not, I had some luck getting parts at Checker Auto Parts (if you have one there) for a few things like my valve cover gasket. Both companies in first sentence have web address's of:
    www.memphisequipment.com
    www.surplusjeep.com
    If you got time and don't wanna spend money, you can cut out your own.
    1969 M715 WO/W
    SF Bay Area, CA
    Napa online shows the oil pan gasket kit for about $26,
    p/n: NGA OS20927
    Port Orchard, Wash.
    Quote Originally Posted by hiker View Post
    p/n: NGA OS20927
    Have you used that one and can confirm that it will fit our military 230 Tornado engines? Or is that one of the parts that works on both the military and civilian versions of the engine?
    -- Tim Taylor
    The civvy and mil oil pans are the same....so the gasket should work there..
    The rear min comes in 2 flavors though...a thin one, about ¼ inch wide, and a thck one, about ½-¾ inch wide...make sure you get the right one...usually the mil one is the wide one.
  1. Gasket and Seal Set?
    Last Post: March 1st, 2010, 03:50 PM
  2. Oil Pan Gasket
    By AWB in forum Stock Tech
    Last Post: May 17th, 2009, 07:38 PM
  3. Gasket, yes or no?
    By fng in forum Stock Tech
    Last Post: March 2nd, 2009, 07:53 PM
  4. Gasket or no gasket?
    Last Post: October 8th, 2008, 11:23 AM
  5. Gasket
    By carmen in forum Open Discussion
    Last Post: April 26th, 2007, 01:06 PM
