Results 1 to 4 of 4
Thread: PTO mounting.
    Washington State
    Default PTO mounting.
    I will be mounting a new old stock PTO for my t-98 trans to run a front mounted Ramsey PTO winch I aquired. I was wondering how easy or difficult this is to setup. I have been told I need to measure the backlash or gear clearance? How should I do this? I have 3 different thickness gaskets that came with the PTO. Any help? Thanks guys.
    SF Bay Area, CA
    Here's a link to a PDF from Parker, the parent company of Chalsea PTO. If you have dialup internet, it may take a while to download. Page 16-17 covers setting up the pto backlash. You will need to remove the shift cover on the PTO to see (measure) the backlash. The manual suggests the .020 gasket. Robert-ca
    http://www.parker.com/CHELSEA/CAT/EN...1135-M1_US.PDF
    The file is 1.5 meg approx., not too bad on dial up.
    Aug 2013
    Palestine TEXAS
    Default Repaird Hikers Link
    Quote Originally Posted by hiker View Post
    Old thread, but some of Us still have the Np 202's, and will find this useful.
    ( Hopefully, none of Us still have DIAL UP !! )
    The Instructions for setting backlash on the M 715 Stock T-98 Transmission PTO is still listed here:
    Same Page Numbers, as Hiker stated but a new link:
    http://www.parker.com/literature/Che...l_10.03.13.pdf
    hostis est intra portas tuas
  1. hetzer : Cab Mounting
    Last Post: November 10th, 2009, 11:48 PM
  2. Antenna mounting
    Last Post: February 1st, 2009, 12:49 AM
  3. Winch Mounting
    By Barrman in forum Stock Tech
    Last Post: December 17th, 2008, 09:07 AM
  4. Div Np 205 mounting
    By tngreenmachine in forum Modified Tech
    Last Post: April 27th, 2007, 11:56 AM
  5. 205 mounting ????
    By rjenkins in forum Modified Tech
    Last Post: January 9th, 2007, 07:27 PM
