Results 1 to 4 of 4
Thread: distributor help!
    Default distributor help!
    I bought a new distributor cap, off of ebay (a red one) to replace my old cap(a black one) because it was missfiring. When I put the new one. It wouldn't run. So I put the black one back on and it wouldn't run ether. But it ran great earlier that day with the old one on (just missing a little). I don't know what I have done to it. I notice that the part from the cap that touchs the rotor button are alot diffrent in shape between the red one and black one. i need some help. thanks
    Now I need to test the coil to see if that is the problem. Does anyone know how to check with a ohm meter with it out of the distributor? Thanks
    I just checked it with an ohm meter. I'm geting 0 ohms between the primary and 15,000ohms between the secondary. Can anyone tell me if it is bad. Thanks
    Coil tests are on this page:
    http://www.m715zone.com/vb/view.php?pg=24_tuneup
    and in the ignition section of this page:
    http://www.m715zone.com/vb/view.php?pg=20chap2-6
  1. Can't get distributor off 230
    By robsgp in forum Open Discussion
    Last Post: December 1st, 2014, 08:03 AM
  2. Distributor upgrade for 230
    By compexp in forum Modified Tech
    Last Post: February 10th, 2008, 08:00 PM
  3. Need a distributor cap
    By viperman in forum Stock Tech
    Last Post: February 4th, 2008, 02:45 PM
  4. need a distributor
    By 4x4wheelin in forum Stock Tech Archives
    Last Post: March 26th, 2004, 10:33 AM
