Results 1 to 10 of 13
Thread: Star location
    Default Star location
    I was wondering if anybody had pics of original markings or markings that they had copied exactly from the originals. Thanks Dave
    Geneva, FL
    Blog Entries
    1
    My truck is exactly as it was originally with the exception of the hood number. It is a different number.
    teking do you have pics you can share with the rest of the class...
    Zone holster maker
    Feb 2004
    Silver Lake Sand Dunes MI
    My truck has all the original markings on it that were found when the truck was stripped to bare metal. Everything is in it's original location and size as it was found except for the bumper unit numbers. That was due to my truck not having a bumper when I found it. I also read through the manuals to double check my findings.
    More pics can be found on my restoration site http://www.davidallenracing.com/M715.htm and my decal markings site http://www.i2k.com/~schwarzd/
    Dave
    Geneva, FL
    Blog Entries
    1
    Yep that is exactly as mine ...
    How does one detemine the numbers that were originally on one's truck?
    1967 & 1968 M715
    The ChopTop
    Info that should help:
    Paint:
    From 1944 to 1957, the US Army used Semi Gloss Olive Drab #23070. It was then replaced with Semi Gloss Olive Drab #24087. This was used until the 4 color cammo scheme was introduced in the 1975-76 timeframe. So any US Army truck built in the era of the M715's would have come out of the factory wearing the #24087. The 4 color cammo pattern gave way to the present 3 color cammo pattern, the NATO pattern, in the mid-80's. Many M715s were out of service by then but may have been repainted to the 4 color cammo pattern before being removed from service. Undoubtedly some were in service long enough to possibly have been repainted to the newer 3 color cammo pattern as well leaving all 3 open to use with the Semi Gloss Olive Drab #24087 being original factory stock for the US Army trucks and the 4 color cammo being next in popularity. The US Marine Corps used a different paint on their vehicles. The correct paint for those is #24052 Forrest Green.
    General Markings info:
    From the Factory, the markings on the vehicles would be few. Things like the Unit Markings, the bumper numbers, would have not been applied until the truck reached the unit it was intended for. So to make a "Correct Factory" look, one would have no such markings. The hood numbers , stars and some other stenciling would be there.
    Painted Markings:
    From about 1957-1975, most of the markings on the vehicles were painted on using Lusterless White #37875.
    Pressure Sensitive Markings:
    Begining in 1964, permanent pressure sensitive markings were allowed to be applied. Note all markings should be the same type....either painted or pressure sensitive, but not a mixture except for the stars, which are allowed in either style even if that differs from the style of the rest of the markings. For US Army vehicles the pressure sensitive markings are white vinyl. For the US Marine Corps, yellow vinyl is used. For the US Air Force yellow reflectorized markings were used on the blue trucks but not on olive drab trucks....though I have no notes on what they used on those.
    Stars....correctly called the National Symbol:
    The National Symbol, the 5 pointed star, is used on all the trucks except those of the US Marine Corps and are to be applied in the largest area of the:
    Top of truck, 20 inch size for the hood
    Both sides of truck, 14 inch size for the doors
    Front of truck, 5 inch size for the front bumper
    Rear of truck, 6 inch size for the tailgate
    It is never applied to canvas or vinyl tops or covers. It also is not applied to any area where it could be covered up by canvas, windshields when folded, or where any spares or other items might hide it.
    As to the orientation of the National Symbol, on horizontal surfaces, one point should point directly forward toward the front of the truck. For WWII vehicles, the star points the other direction, so one does see the National Symbol pointing toward the rear on the older trucks, but it is not correct for the Vietnam era and later vehicles. On vertical surfaces, one point always points straight up to the sky. One may see WWII vehicles with the National Symbol in a circle. This is an invasion marking and is never correct for the M715 family. Note that ambulances, like the M725, would never have the National Symbol.
    Hood Numbers:
    The numbers found on the hood of military vehicles are divided into 2 parts. The letter/number code is referred to as the Registration Number, or sometimes the USA Number, and the Agency ID, which tells the branch of service, for example US Army. The Registration Number is put on the vehicle at the time it is originally built and it stays with the truck for its entire lifespan. Only in very unusual cases is it ever changed. Around 1964, the specification for the markings of the Registration Number and Agency ID was set at 3 inch figures. Only where space did not allow for the use of the 3 inch size was a smaller size allowable. The military technical bulletin defining proper markings indicates that, for the Agency ID, there should be periods after the U and the S in U.S. Army. Looking carefully at the pictures and illustrations in the same publication shows no periods are shown. Pictures from Vietnam show a mix of some trucks with and some without. It certainly appears that the abscence of periods is more common than the inclusion of them in this area. Placement is on the hood, on the sides at the edges and on the tailgate. On the hood, the Agency ID is on top with the Registration Number being applied 2 inches below. On the tailgate, they are in a line, not one atop the other.
    What the numbers and letters in the Registration Number indicate is the subject of many inquiries I receive. Here is the information I have on this subject:
    Starting in 1960, anything older does not apply, the hood numbers would look something like this example:
    3A 0001
    The 3 indicates a medium weight vehicle class. I believe this class runs from 1 1/4 ton to 5 ton. Any military vehicles, like 6X6's for example, with a load rating higher than 1 ton and up to and including 5 tons would start with this number. The A and the 0001 work together to show which number of medium weight vehicle built that this one is. A 0001 would be the first, A 9999 would be the 9999th one built. The next one, #10,000, built would be B 0001. Once 9999 were built as B's, the marking would change to C 0001 at number 19,999 and so on.
    In 1968, the military changed the Registration Number system again and now included a year in the Registration Number as well. A sample of this style looks like this:
    03A00168
    The 03 still refers to the medium weight vehicle class.
    The A and the 001 work together just as described for the earlier system, though only accounting for 999 vehicles before changing to the next letter instead of the previous methods 9999 limit. The 68 is the year, 1968, and does not change for any vehicle made that year.
    Due to the fact that ALL medium weight vehicles, not just the M715/M724/M725/M726's, are included in these numbers, trying to use the Serial Number stamped on an M7xx to establish the Registration Number for the truck in question, when the original is not known, becomes an impossible task. It is possible to create a period correct looking number but establishing that it is the correct one for a given truck just wont happen.
    In the early 70's the system changed again to the system that is still in use today. So our trucks fall into one of the 2 methods above, unlike the WWII trucks and unlike the modern trucks as well.
    Unit Markings:
    These are the number/letter markings found on the front and rear bumpers of the trucks. The US Marine Corps did not use these markings. For the other branches of the military, these markings were required to be in the largest practical size but not over 4 inches in height. Any symbols used outside the normal letters and numbers were to be as close to the same size as the lettering. Initially these were to be of paint that could be removed with gasoline or removable vinyl letters.
    Reading such markings from left to right on a front bumper would tell us a lot about the vehicles assignment, to include:
    1. The Major Command it is assigned to
    2. The Intermediate Command it is assigned to
    3. The Unit or Activity it is assigned to
    4. The vehicle number for convoy purposes, aka: Order of March
    If the truck in question was actually in Vietnam, it is possible that it could have had artwork on it that was added over there and was unit specific or one of a kind. This would be like nose art on WWII fighters and bombers. I have never seen any on an M715 but that doesnt mean there wasnt any. Anything of this type would need to be researched to find correct pictures of a specific truck with specific markings. Such markings are outside the scope of this posting.
    Miscellaneous Markings
    There are several other markings one may encounter on military trucks. Common to the M715/M724/M725/M726's are tire pressures, maximum permissible speed and fuel tank expansion. The following are from the military regulations regarding these markings as they apply to our trucks:
    Tire Pressure should be marked in 1 inch letters above each wheel. It should also be marked on the dash even though it it often listed on the dash mounted data plate. They are to be marked with the letters TP, location, if needed, and then the pressure, where TP indicates Tire Pressure, example:
    TP Front 25
    TP Rear 45
    Maximum Speed, if not listed on the vehicle operation data plate should be stenciled on the dash in this fashion:
    MAX SPEED XX
    Where XX indicates the maximum speed.
    (Note: Even though the max speed is listed on the vehicle operation data plate, many M715's, including mine, have the MAX SPEED stenciled on the dash....mine lists 60 MPH as the MAX SPEED, I have seen 55 MPH and 45 MPH as well. I am not sure what the data plates on all the trucks reads, if it is the same as the stenciling or not, but I know this number does vary.)
    Fuel Tanks that are not readily visible are to be marked as near as possible to the filler neck with 1 inch letters stating the following:
    CAUTION DO NOT OVERFILL-ALLOW FOR EXPANSION
    It is interesting to note than on vehicles where the tank is easy to see, like a 6X6 with the tank out in the open, the marking is a line placed 2 inches down from the top of the tank and the words:
    CAUTION
    DO NOT FILL ABOVE THIS LINE
    So one could make the assumption that our tanks should not be filled higher than that level as well. This gives an idea what the intent was from the military perspective on "overfilling".
    Bridge Weight Classification Markings
    The Bridge Weight Placard that attaches to the front of the truck can come in yellow or Olive Drab. I do not have any information on which is correct for our trucks but I have seen both. I do know that the yellow used is Lusterless Yellow #33538 and the black that is used with the yellow is Gloss Black #17038. Besides being on the grille mounted placard, a 6 inch circle in yellow on the doors with the base weight class on it is appropriate. In our case the base weight class is 4.
    Good Driver Sticker
    Also known as DA Label 76, the Good Driver sticker is a list of 20 items that the military driver should live by. These are correct for all years of the M715/M724/M725/M726 production. It is a water transfer decal in yellow with a black border on it. Most commonly on the M715, they are found on the dash panel, either to the right or left of the steering wheel. They are sometimes found on the drivers door but this is uncommon.
    Gauge Markings
    The military regulations state that all of the gauges should have their function stenciled below them in white on the instrument panel. I dont remember seeing an M715 with this stenciling before a restoration except under the high beam indicator where High Beam is usually stenciled and under the fuel gauge where Fuel is stenciled. I have seen a few trucks where the owners added this stenciling during a restoration. I think this one could go either way and actually may not have been part of the original stenciling applied either at the factory or with the unit unless it was so specified in a specific unit or command. It does not appear to have seen widespread application on these trucks. Even in the manuals, there are occasionally pictures which show 1 or 2 gauges with a stenciling but not all 4 and not always the same ones when there are any marked.
    That is fantastic, thank you!
    1967 & 1968 M715
    The ChopTop
    So... how lame would it be to use 4077 for the unit number?
    1967 & 1968 M715
    The ChopTop
    Hood Numbers
    If your hood numbers have been removed as most have been, try looking under the hood or possibly on the dash. Both trucks I have owned had the numbers stenciled under the hood. I believe this was done when they were camoed with the four color camo. I have heard of some vehicles having had the numbers stenciled onto the dash but I have not personally seen this. Maybe this will help folks to find there hood numbers. Dave
  1. Star on winch bumper?
    By Cornholio in forum Stock Tech
    Last Post: September 20th, 2009, 09:12 AM
  2. Hood Star
    By rboltz in forum Stock Tech
    Last Post: August 23rd, 2008, 03:05 PM
  3. Lone Star MVPA
    By Barrman in forum Open Discussion
    Last Post: December 23rd, 2007, 12:34 PM
  4. White star on my hood...
    By MitchB66 in forum Stock Tech
    Last Post: January 28th, 2007, 06:27 PM
