Results 1 to 4 of 4
Thread: How do you remove Small window in door??
    Oxford, Ohio 45056
    Default How do you remove Small window in door??
    I have taken the obvious screw out in the jam and the obvious screw on the inside of the door towards the top.
    I thought you could pull it out , but I am wrong.
    Is there another screw under the inside removable panel or what ??
    There are a total of three...on this page is a pic telling where:
    http://www.m715zone.com/vb/view.php?pg=10chap1-4
    Its Figure 15...and I see that it says Widow...not window....something else to correct...
    Oxford, Ohio 45056
    Thanks John.
    No sweat!
  1. gaskets under door handles, door panel clips, widow clip
    By Mudkaiser in forum Modified Tech
    Last Post: February 17th, 2024, 10:33 PM
  2. Another way to remove runflats
    By rpgdeity in forum Open Discussion
    Last Post: November 30th, 2008, 10:35 AM
  3. Replace with bolts and remove studs???
    By viperman in forum Modified Tech
    Last Post: February 5th, 2008, 07:49 PM
  4. Door Window Refurb...
    By Snuffy in forum Open Discussion
    Last Post: June 11th, 2007, 08:01 PM
  5. How to remove ignition wires.
    By knave in forum Open Discussion Archives
    Last Post: May 18th, 2004, 04:43 PM
