Results 1 to 2 of 2
Thread: Steering Wheel Size
    Default Steering Wheel Size
    Need to get a steering wheel ordered for the waggy column (see build pics thread).
    Any suggestions on the diameter? The truck will/does have power steering.
    Jason
    The stock wheel n the M715 is 16 inches one way and 17 the other...its sides are more flat and top and bottom edges are more round....I wanted more leg room...the 16 is a little close, the 17 hits me...
    I mounted an aftermarket wheel with a kit and went to 14.5 inches roughly...no power steering but gives the room I need and I can still work it around good...not too small to work with manual steering...
    With power you could go smaller, but if you ever lose the pump on the trail, it will be harder than heck to steer the smaller the wheel is...and these trucks can take a pump out on the trail...ask Drew about his fun at FE2000....
    I would stay with something in the 14-15 inch range...common size and still gives a good lever if there is a problem.
  1. Steering shaft size.
    By BulletSponge in forum Modified Tech
    Last Post: April 23rd, 2009, 12:03 PM
  2. Steering wheel replacement.
    By rboltz in forum Stock Tech
    Last Post: November 29th, 2007, 09:37 PM
  3. Steering wheel adapter
    By fng in forum Modified Tech
    Last Post: October 31st, 2007, 10:33 PM
  4. Grant Steering Wheel
    Last Post: August 28th, 2007, 06:50 PM
  5. 4 Wheel Steering?
    By over2land in forum Modified Tech Archives
    Last Post: March 22nd, 2004, 06:08 PM
