Now that my home phone is fixed and my dial up working again, I can catch up on progress made over the weekend.
Agengr was over again to work on his truck. In between rain storms, sanding sessions, reloading and painting, we decided to hook up the NOS hand throttles he picked up. This is the style with T H R O T T L E stenciled on the T handle and a ratchet catch depending on which way the handle is turned.
His truck still had the stock pedal linkage. I have the left overs from several add on cruise control kits and we used those parts to make a flexible end that would allow the handle to work and the pedal to be pushed without the handle moving as well. To connect the chain link to the cable, we took a 5/16" x 1" bolt and drilled a 3/32" hole in it. Put the end of the cable through the hole and tightened a bolt on it. Then another cruise control part was looped over the bolt and another nut tightened on to hold it. The pedal end was slipped on behind the cotter pin. Here is what his looks like.
While he was crawling under his dash to install it, I looked through the stuff left and came up with a different way. I found a 3" long cable with a loop at one end and a brass block at the other. I melted the brass off, made another bolt with a hole in it and then put both the free flexible cable end and the handle cable through the same hole going in different directions and tightend a single nut down on them. I had already changed out the linkage on my pedal end to allow a cable to be tightened down on (Thanks again Al, I didn't put a flexible end on the cable from you and broke it.). I just looped the loop over it and used a cotter pin to keep it on. Here is what mine looks like.
We both got done around the same time. We were playing with them checking things out and then went back to painting for him and reloading ammo for me. (I was down to less than 40 rounds of 9mm at one point last week. I got it back up to a livable 360 now) Here is his paint haul for the weekend. Hood, bumper, fording intake, receiver hitch, b/o gaurd and base, horn button and a pile of fasteners.
