Results 1 to 3 of 3
Thread: disc brakes?
    Default disc brakes?
    I have converted to disc but am in the process of getting a mastercylinder and wondered if the resevoirs and lines have to be the same size front and rear? I know that alot of you have swapped in the vette master cyl. but can that be added to hydroboost?
    It can be added to hydroboost if you want.
    Did you do a 4 wheel disc swap or just the front? If you did 4 wheel, the reservoirs should be the same size...if you just did the front as disc but the rears are still drum, then you need different size reservoirs for the front versus the rear.
    Thanks that is just what I needed to know.
  1. Disc Brakes Arrived!!!!
    By FSJGuy in forum Modified Tech
    Last Post: May 22nd, 2007, 09:56 AM
  2. Disc Brakes Arrived!!!! (Part II)
    Last Post: April 28th, 2007, 11:29 PM
  3. F-450 disc brakes and 8lug conversion
    By Willie_715 in forum Modified Tech
    Last Post: March 14th, 2007, 03:22 PM
  4. Dana 70 Disc brakes 8x6.5"
    By tngreenmachine in forum Modified Tech
    Last Post: February 21st, 2007, 04:34 PM
  5. Looking to get disc brakes
    By 40Grit in forum Modified Tech Archives
    Last Post: May 13th, 2004, 01:42 PM
