Ok, with the help of a motorcycle jack and occasionally my wife, I got the fuel tank installed. As part of the rebuild I put in a new sending unit from autometer that matches the guage I installed in the cluster.
I carefully followed the instructions included in the box as for the proper adjustment of the arm and stem. (The depth of out tanks is 15 1/2 inches deep if anyone cares) Got it all hooked up, grounded and installed. Poured in 4.8 gallons and looked on the guage....read zero. Decided to do some trouble shooting, checked all the connections, and decided to try 5 more gallons. Ok, poured that in (now approx 9 gals onboard) checked the guage and it now reads 1/4 tank. DANGIT!
Without having to pull out the cluster does anyone know if the guage has some kind of adjusment screw on the back? If not then I guess I'll have to drop the tank and pull out the "sealed in" sending unit and make adjustments from there huh? Anybody got any ideas before I have to do all that?
