Results 1 to 10 of 13
Thread: Guage replacement-- 12 volt
    Farmington hills MI
    Default Guage replacement-- 12 volt
    I"m getting ready to replace my guages in my modified truck, (12 volt), I have not bought guages in 20 years.
    I saw where fng replaced his fuel guage and set up the sending unit, sounded like he is all set for fuel. He did mention that one of the guys on the site found a fuel sending unit that bolts up to the stock tank, he said that someone may have a list of numbers.
    I would like to swap out all of my guages to a matched set. I was looking for ones that would be preferably black face, black bezel, white numbers, letters, needle, If I can't get them in a black bezel, I want to go stainless steel, I should go s.s. just for rust reasons, but I am worried about the sun reflecting off of the bezel and into my eyes when the top is off. Have any of you guys had a problem like that with the reflections?
    Back to the guages, What is a good brand, and a good place to buy them? I have looked at Summits on line cat. and others, till I'm blue in the face.
    Try a search for Stewart Warner and military gauges or Datcon heavy duty gauges. You'll find many with mill finished bezels, but they can be painted to your specs.
    If your tastes are likes mine, stay away from AutoMeter gauges, as their bezels are too fat and deep; at least the type I've seen recently.
    Washington State
    I just purchased all new gauges, and I wanted gauges just like you mentioned above. I looked at Stewart Warner, and Datcon and although I liked them, they just didn't seem quite right. I then found Isspro gauges and knew immediately those were the ones I wanted. I can even get you part numbers if you wish for the gauges I purchsed. You can find Isspro online and they are in Portland Oregon. I purchased Mechanical speedo with trip odometer 33/8", mechanical tach. with hour meter 33/8" and then water temp, fuel level, oil pressure and volt meter in 21/16" black bezels, black with white lettering. Good luck on your decision.
    Lone Pine, CA
    Stewart Warner made the original gauges and their deluxe series is identical, in 12 volt but with chrome bezels. Paint the bezels OD and you wouldn't know the difference.
    The fuel sender bolt pattern is a standard kinda thing, most all "universal" sending units will match. You have to know which way the arm is oriented in relation to the offset screw holes because it bolts in only one way. It sounded like FNG's Autometer sender could go either way but the S-W universal sender has either a left facing or right facing arm. The speedway motors catalog explains it well.
    Springdale, Arkansas
    Although you've already been advised against them, here's a picture of my autometer guage's and my panel switches. Yes they do have a thicker bezel but I actually don't have any problem seeing them when they're within their normal operating ranges. Not only that but I really like the red inner lighting and the black contrast against the OD.
    FYI I'm also posting some other "I'm Finished" shots on the open discussion board.
    Farmington hills MI
    Nice pics fng, but after checking out the ones that fisherman pointed out, I found that the ones I'm looking for,I really like the Isspro ones.
  1. 12v guage questions
    By ryanroo in forum Modified Tech
    Last Post: January 25th, 2009, 05:06 PM
  2. Guage cluster wiring
    By pghjeeper in forum Stock Tech
    Last Post: June 11th, 2008, 09:39 AM
  3. 12 volt tach, 24 volt system
    By vacca rabite in forum Modified Tech
    Last Post: May 19th, 2008, 03:12 PM
  4. stock guage questions
    By farm715 in forum Modified Tech
    Last Post: March 2nd, 2008, 09:49 PM
  5. 24 Volt Replacement Ignition Coil
    By law in forum Stock Tech Archives
    Last Post: May 12th, 2004, 12:33 PM
