Results 1 to 10 of 10
Thread: Steering wheel adapter
    Springdale, Arkansas
    Default Steering wheel adapter
    Did a search and found no results.
    I was poking around a salvage yard yesterday and found a really sweet steering wheel in a dark tan color that matches the interior and top. I figured since it came out of an old wagoneer it'd fit?!? Just had to have it. It has a shallower profile so I can get my fat gut in behind it easier and the wheel isn't always right in my lap.
    After much swearing, pounding and a quick trip to Harbor freight for a steering wheel puller I finally got the old one off. Tried to test fit it on the splines and it wouldn't go on....dang!
    Question is: will it fit or do I need an adapter? If I do need one does anyone know which one to ask for?
    Thanks, T
    If it is a pre 74 wheel an looks like the stock one....16 inches top to bottom, 17 inches side to side and 2 spokes, then it should fit.
    I have seen them in different colors, but for the manual steering setups, they are the same wheel...just the color changed.
    I guess I dont know if the power steering equipped ones use a different wheel mount pattern...
    If its 74 and up, forget it fitting a stock column.
    Any Ideas on an adapter?
    Adapter....JC Whitney sed to carry them...they are not online at their site anymore but are supposed to be in their catalog..."your vehicle" will be a 1967 Gladiator pickup...doesnt matter the motor or model...tell them its a J2700 if they need a number.
    Thats how I got mine...but anymore I cant find them online.
    Huntingtown,Md.
    Just picked up an Grant adapter, # 4403, cost, $30.00.
    Where did you pick it up?
    woodland ca
    i have a grant wheel on mine, i dont know how its mounted, but i can check it oout since i need to fix it anywase
    my signature is sweet huh?
    Huntingtown,Md.
    Auto Zone.
    Lone Pine, CA
    If that was an OEM steering wheel it should have been manufactured with the splines integral to the wheel. Those adapters work with universal 3-bolt (or similar) steering wheels. If the splines don't match I'd guess the best way is to either modify the stock column or swap to a late model column.
    Thank you airborne....so we have:
    AutoZone Part # 4403, Grant steering wheel adapter
  1. safaritow : Steering wheel adapter
    Last Post: December 15th, 2009, 08:16 PM
  2. Grant steering adapter
    By Kamikaze12volts in forum Modified Tech
    Last Post: October 27th, 2008, 12:02 PM
  3. grant steering wheel adapter
    By guswheels in forum Modified Tech
    Last Post: April 30th, 2008, 08:57 AM
  4. Wheel adapter 8x6½" on stock diffs
    Last Post: January 22nd, 2008, 09:40 PM
  5. 4 Wheel Steering?
    By over2land in forum Modified Tech Archives
    Last Post: March 22nd, 2004, 06:08 PM
