Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: 7 Round H4 Headlight Conversion
  1. #21
    Quote Originally Posted by Kaiserjeeps View Post
    There is nothing like good lighting. Those replacements are so much better than USA ones. The light distribution is superior on the European buckets. Tim I run 80/100 bulbs and absolutely never get brighted. The cut off line is fine. The best part is the shoulder 45 degree angle beam that lights up the right shoulder. Get the 80/100's which are more common and aim them right. They will then compare to todays modern low beams which are crisp.
    This is a good place.
    http://www.rallylights.com/
    Never buy the Hella Vision Plus replacements. They are a neutered version of the standard E beam and only mildly better than DOT bulbs. A total waste of money.
    I will walk you through building a relayed low and high circuit. It's easy and very cheap. Thanks for the heads up.
    Don't want to hijack here but I want some of these! Add on's.
    These are able to be focused from long distance to flood with a twist. These are Aussie made and on all the truck trains over there.
    http://off-roadlights.com/xcart/prod...cat=250&page=1
    Tim have you considered some AUX lighting up front? What about extra back up lights mounted sideways so they can swing around the side of the Jeep? Camp site light or change a tire.
    What about chassis lights in case you have a night time repair? Under dash lights? Dome light?
    Christmas is coming you know. It would fit right in.
    I know this is a year-old thread but I need to address headlights in three vehicles: 81 Scrambler (has conversion bulbs but I think they are frying my wires); Big Cheese, my M715 that is at Randy's right now; and my daughter's M1009 that has stock setup. With potentially three setups needed "I will walk you through building a relayed low and high circuit. It's easy and very cheap." sounds great.
    How do I...?
  2. #22
    How about like this?
    http://www.ford-trucks.com/article/i...r_Brights.html
    (If you guys can get past the Ford part!)
  3. #23
    Jan 2008
    Montreal Canada
    On mine i have hella conversion lenses with bi xenon 55 watts HID .... I was having some issues with the 3 levers switch because with the trailer on and the flashers activated , the inside breaker was getting too much current and was triggering the safety. Now with the HID, i only draw .250 A to activats the relays.
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
  4. #24
    I an interested in selling my Hellas...bulbs, housings, and connectors...dont have the relay part but that would be seperate anyway.
    Pm if you are interested.
  5. #25
    I have done several of these in the past, from scratch, and that is by far the best set of instructions I have ever seen. Wish I had it then, rather than having to draw up my own.
  6. #26
    OOPS, meant to quote Hetzer. Don't know how that happened.
  7. #27
    Jan 2008
    Montreal Canada
    This is my conversion .... hella with HID
    M104A1 trailer
  8. #28
    Nov 2009
    Amish Country PA
    I have (in my Jeep XJ) AUTO PALS you can get the set of 2 with the bulbs off ebay for around $40 and have a great result. I have not tested them side by side to the hella but they were a huge improvement from stock on my 97 XJ.
    these are available in round as well
  9. #29
    Feb 2009
    Northern California
    Cibie (with a little dingle over the e that I can't type) makes the best h4 housings... except to pay a bit more though.
    As a warning, don't ever put HIDs in housings meant for halogen bulbs... may look fine to you, but it will blind other drivers with annoying glare. If you want HID, get a complete HID kit with proper housings.
    http://www.danielsternlighting.com/p.../products.html usually has good prices on the cibie halogen headlamps, and he's nice and helpful too.
    --Randy
  10. #30
    Quote Originally Posted by randygar View Post
    Exactly!
    I've seen so many try this and swear its great. From the driver's seat, it is. From the perspective of the approaching driver, its just plain bad.
    What you get is more of a light scatter, than a focus. Similar to a flood light vs. a spotlight, which is in essence what a pair of focused sealed beams really are. Add to that, the light emitted is very high on the white end of the scale, which will leave you seeing spots after an encounter with them.
  1. 715 headlight problems
    By TroyWilliam in forum Open Discussion
    Last Post: December 25th, 2018, 11:51 PM
  2. Headlight switch and turn conversion
    By CHRIS UNGER in forum Modified Tech
    Last Post: March 22nd, 2010, 08:02 AM
  3. Headlight springs
    By Chumley in forum Stock Tech
    Last Post: August 20th, 2008, 09:02 PM
