Results 1 to 10 of 10
Thread: fuel pump
    Default fuel pump
    What are the options for rebuilding the stock fuel pump? I had my fuel pump rebuilt awhile ago by a place out of Hemmings and now once again fuel is coming out the vent line. Luckily I left the hose off of the air cleaner so it did not washout the engine again.
    Go to the manuals section and scroll down. There is an article about modifying a Chrysler pump to fit the 230......
    Default pump
    If I remove the stock pump, what do I do to get my vacuum for the wipers? Just hook to prted vacuum from the intake?
    That would be a problem if you are running the stock vacuum wipers. I suppose that manifold vacuum with a storage tank may work. About any late 70's early 80's US cars had the vacuum tanks under the hood. The ones that look like a coffee can.
    Ported vacuum won't work. It it only present off idle. manifold vacuum is constant even at idle, although it will drop off under acceleration, hence the need for a storage tank.
    there is no ported vac on the 230
    68 M-715 MVPA #2710
    The drop off in vacuum at higher rpms led to the vacuum pump on the motor...
    You can get a kit to rebuild the stock fuel pump from Then-Now.com. The rubber in the new kit is compatible with the new gasoline blends (unlike NOS stuff that doesn't last long).
    Do these kits include the vacuum pump side also?
    I think it did, but to be sure just ask when you call them to order.
    You can get the kit with or without the vacuum part...see this page:
    http://www.then-now.com/The_Cellar/cellar.htm
    Excerpt:
    "SINGLE ACTION" (PUMPS FUEL ONLY) KIT: $ 29.50
    (these do not cover dual diaphragm Marine pumps- see rebuilding below)
    "DUAL ACTION" (PUMPS FUEL and Boosts Kit: $ 49.50
    Manifold VACUUM for wipers and heater controls)
  1. Fuel Pump
    By gargemel_622 in forum Stock Tech
    Last Post: September 7th, 2009, 12:10 PM
  2. need fuel civy fuel pump #s
    By jpsnblood in forum Stock Tech
    Last Post: June 24th, 2009, 09:00 PM
  3. Fuel pump ?
    By ryanroo in forum Stock Tech
    Last Post: October 7th, 2008, 09:47 PM
  4. fuel pump doesn't pump.
    By sf38a1 in forum Stock Tech
    Last Post: April 11th, 2008, 08:58 PM
  5. 230 fuel pump
    By krek in forum Stock Tech
    Last Post: May 5th, 2007, 09:29 AM
