What is the number for a replacement. I pulled my burned filter out and there are no numbers on one side. Other side is burned. I went to Advance Auto and compaired and no luck. Thought it might be the same as the J trucks but no luck.
The following are for the carb mounted air cleaner. the later hood mounted style, we dont have a reference for.
On the early models which is mounted directly above the carb, use a NAPA GOLD 2050 or a FRAM CA151PL.
from wi715 #1743 4/30/99
WIX #42050. You'll need to order it at an autoparts store.
Mozarkid #564 12/9/98
Last edited by Binford; January 7th, 2008 at 11:16 AM. Reason: Jon's "O" was stuck on his keyboard (keyword spelling correction)
Thanks for those numbers. I called Advance Auto, and they told me they would get it in 5 days. So I called the local/small town NAPA, and they had it in stock for $14.31 after taxes! I was expecting to pay $30. It is a real tight fit (NAPA Gold 2050). I think it is fine though, dont have an original to compare it to.
