Results 1 to 8 of 8
Thread: Cummins Carnage
    Default Cummins Carnage
    Thought some of you might get a kick out of these photos. A friend of mine that parts out dodges gave me this engine. He said it had a knock in it, sounded like an injector or valve. Well I took the head off and this is what I found. OUCH. I have never seen one this bad. The other five pistons and cylinders look great, no wear at all.
    Aug 2007
    N. Liberty Iowa- 41deg 44' 48" N, 91deg 36' 36.4" W
    Nothing like some good ol' fashioned Cajun cookin'
    M-715's as big as FSJ's come
    Jan 2007
    woodland ca
    aww, shes still got a couple miles left hell its good. throgh it back it and go
    my signature is sweet huh?
    Huntingtown,Md.
    M-B run 5cyl all the time. Drive it!
    Well for those who are curious I took the head and piston to a friend of mine that is a cummins mechanic to see what happened, and if the engine is salvageable. He noticed that the injector for that cylinder was not sticking out as far as the other five. We pulled it an saw that it had two seals on it, and he thinks that that cylinder was sucking air causing it to run lean and heat up, melting the piston. Looking at the block, he said to put a new piston and rings in it, and it will be good as new. So I just got a good cummins engine for the price of an $80 piston and rings.
    SWEET, I love that!
    Got another? I wan't one..............
    Quote Originally Posted by sermis View Post
    I go by there all the time if I see another one I will snag it for you.
  1. Cummins
    By Snuffy in forum Modified Tech
    Last Post: September 29th, 2008, 08:55 AM
  2. What about a 6AT Cummins?
    Last Post: September 23rd, 2008, 10:59 AM
  3. cummins 4bt
    By lukeisaduke in forum Open Discussion
    Last Post: July 3rd, 2008, 05:29 PM
  4. 4bt cummins
    By hunter in forum Modified Tech
    Last Post: December 15th, 2007, 04:29 PM
  5. Clutch carnage...how did I do this?? Long!
    By brute4c in forum Stock Tech Archives
    Last Post: February 22nd, 2004, 04:08 PM
