As mentioned in other posts, my '715 came with SOME 12 volt conversion and I am going back to 24 volt. The battery now is 12 volt for sure and the starter operates with a remote solenoid with a key switch on the dash. There are no markings on the starter. I got a 24 volt original starter to replace the existing one and this one has no markings either. They are identical in appearance.
I now wonder if the one in there now is in fact a 24 volt, just turning over slower on 12 volt. Do 12 volt starters exist for the '715 that do not have the attached solenoid like most starters? In other words, 12 volt starters that need either the foot switch or a remote solenoid to operate?
I can do pictures if that will help but not much to show.
