I want to lift my truck about 8 in on a low buget but i have full access to a machine shop,I would like to hang the front axle under the springs with about a 4in block between the axle and springs i think the 4 in block will give the tie rods clearence from the springs on the rear axle i am thinking to flip the shackles and spring hanger and 4 to 6 in of block i am thinking to make the blocks shaped like \_/ with the wider top going to the spring to reduce the axle flexing the springs also probly ad a leaf from a 2 1/2 ton truck I scraped out.the truck has a 300 ford 6cyl and I will be running stock wheels 34 to 38in tires either grip spurs or the non directional gi tires.any sugestions or advice if this will work or not or problems I might have ? I plan to start on it this week end thanks
