Results 1 to 10 of 51
Thread: Part numbers that may help???
    Default Part numbers that may help???
    Here is a small list of stuff that I have and have been asked for.
    First the radiator conversion.
    Upper hose (NO CUTTING REQUIRED): Flex hose _2168 ***Can not read first letter or number***
    Lower hose ( Cutting required at water pump hose is too long)
    (B) 70081CS
    Conversion Radiator: THIS RADIATOR IS EXACT FIT REQUIRES DRILLING OF 2 HOLES THAT IS ALL 10 MINUTE INSTALL!!
    http://cgi.ebay.com/ebaymotors/Jeep-...em120218173329
    This is where I got my radiator! GOOD STUFF.
    These numbers are from ADVANCE DISCOUNT AUTO PARTS. Im sure they are able to be cross referenced.
    Felpro OIL PAN GASKET:
    OS 5449 C
    Tune up #'s for distributor by CARQUEST
    :POINT SET AL5486P
    :ROTOR AL-151
    :CONDENSER AL118
    Hope this helps, these are parts that came with my jeep along with many other parts. If this is old news delete the thread. Thanks again and hope it helps a few of you.
    67 in progress.
    Chris.
    guess not?
    67 in progress.
    Chris.
    Interesting list...thanks for posting it.
    We have some different numbers for the rotor and condensor and point set...these are for the stock military waterproof ignition on the 230?
    Just want to make sure...thanks!
    well, when I bought the jeep it came with all sorts of stuff. I have like 3 distributors 2 are completely intact and look new. all the parts in there look EXACTLY like the parts I listed. I dont know what would be different. If you want I can take pics of them to decifer.
    I also have like 5 of the steel caps for the distributer and 4 or 5 of the inner caps. Everything looks identical. I hope these are the right parts. I was hopefully going to use them for a tune up/timing/carb adjusting.
    67 in progress.
    Chris.
    Maybe just a different brands part number...could be just that simple.
    Thanks for posting...I know it will help people!
    I post a lot of junk hoping it will help people find stuff. I spend a lot of time looking. I never see much response but I know some people bookmark some of it and never say anything. Don't stop posting stuff you find. It's all good stuff to know. Others should post up cool sites they have found. Some or all of it is worth a bookmark or a favorite to someone.
    Liz, covid, murdered 10/19/21
    Thanks for posting the numbers. Right now, thats not what I am looking for. My yoke came unbolted from my rear axle, and the gears are pretty chewed up, and
    I need the bearing and oil seal . On a Saturday night, I am out of luck.
  1. Part Numbers for drums??
    By 1BadKaiser in forum Stock Tech
    Last Post: August 9th, 2009, 10:52 AM
  2. Brake Part Numbers
    By clearingcrap in forum Stock Tech
    Last Post: June 8th, 2009, 10:37 AM
  3. Part Numbers...
    By Enigmatic in forum Open Discussion
    Last Post: September 17th, 2008, 10:20 PM
  4. Part Numbers
    By Mot-Man-616 in forum Stock Tech
    Last Post: April 6th, 2007, 11:05 PM
  5. part numbers
    By Nuke_afftaburner in forum Stock Tech Archives
    Last Post: May 7th, 2004, 03:01 PM
