Results 1 to 10 of 19
Thread: military colors ???
    Winona, MN.
    Default military colors ???
    Were there any colors other than O.D. green that the military used? My truck is for sale but if I can't get better interest I'm gonna keep it and complete the body. I'd like to do something different than the green if there are other legit colors.
    Check out this thread: Painting an M715
    It has some pictures of trucks sporting the two most common colors for the M715 during it's service life: US Army 24087 and USMC 24052.
    -- Tim Taylor
    On a M715 you might be able to navy gray and air force strata blue, but I've never seen a pic of one painted that way. But that doesn't mean General Flyboy didn't order one be painted strata blue for pass and reviews in 1969 or Admril Leakyboat didn't want one painted gray to hang out on the USS Bigship...
    Zone holster maker
    Silver Lake Sand Dunes MI
    Yep, I've only ever seen 24087 or 24052 in period pics of the M715s. In the 70's they would have been repainted with the 4 color pattern in verious color shades. But that doesn't mean you can't paint it what ever you want. I have seen several people paint thiers desert tan, all kinds of camo patterns, I even have some pics of some trucks with a desert camo on them from the Army. Joe has hit on the other standard military colors also.
    Dave
    1967 Kaiser Jeep M715 weapons carrier:http://www.davidallenracing.com/M715.htm
    1967 Kaiser Jeep M35a2 2.5 ton cargo truck: http://www.davidallenracing.com/M35A2.htm
    1968 M51 Inflatable Chemical Shelter System http://www.davidallenracing.com/M51.htm
    Delta Team Decals: http://www.i2k.com/~schwarzd/
    Then there's the fact that EVERY SINGLE M715 I have seen, without exception, has been a completely different semi-gloss green color altogether. Not 24087 and not 24052, aged, faded, heat-affected, or otherwise. I'm telling you, it's the same color inside the door panel, under the data plate, inside the under-bed storage, etc. Clearly a factory color, and present, as I mentioned, on every M715 I have heretofore seen.
    Sure wish I knew what that color was!
    -- Tim Taylor
    Winona, MN.
    Was white ever used in artic climates?
    I have seen pics of a white M715...it was in Arizona and I dont know the history...might have been to keep the heat absorption down...
    Never heard of an arctic white used on the M715 but there is a cammo pattern in white that could be used...I kinda like it for this climate.
    Was the white one in Arizona Al's before he got it painted? It was the color it was painted after it's military service. "Snowball" I think Al said they called it.
    -- Tim Taylor
    Quote Originally Posted by Binford View Post
    Not rob this post, but has anyone used the red oxide primer referenced in the link above? I'm thinking of painting my truck that color or something similar. It would be nice to see a pick if anyone has one. It's hard to tell the color from the swatch on the computer screen.
    I don't understand your question? You want your trucks color to be similar to the color of the red oxide primer, or you want to use the red oxicde primer under the top color.
    I used the gillespie red oxide primer under the 24087 on my truck and it does make a slight difference in color outcome. Mainly because the 24087 is semi transparent and in bright sun the red oxide refects through to give it a more brown shade and in low light the dark green top coat refects more and gives the trucks a darker green coloring look.
    If you want you're trucks color to be the color of the red oxide primer, then you have to have it custom mixed in a paint. As you can not leave primer as a top coat because it will not be sealed to the elements.
    Dave
  1. Frame colors...your opinions...
    Last Post: July 21st, 2007, 02:39 PM
  2. Army or Marine colors?
    By Maj.Business in forum Open Discussion
    Last Post: April 6th, 2007, 08:39 PM
  3. Military Altinator
    By k8icu in forum Stock Tech Archives
    Last Post: May 6th, 2004, 06:19 PM
