I used the glue on weather stip from Memphis Equipment. It fit well and for only $15 I got more than enough to do both doors.
I don't think there is enough room for the regular style on the pinch welds when you shut the door. I recall I tried that first, then wound up buying the other type. The regular slide on weatherstip was too thick, particularly at the front of the door and kept it from closing properly on my truck.
On the upper frames and windshield, I did use regular weatherstipping from an XJ door, and used several pop rivets to keep it in place. It seals pretty well because it is fairly thick stuff..
