I made a thread about this a year or so ago, but can't find it to finish out the story. Didn't really think about it until I saw the other current thread about battery cables. Here is what I had and what fixed it.
My 396 turned over great when the Optima was under the hood. I added a heater and OBA, so the Optima had to be moved. The custom center console kept the battery from going back to between the seats. Behind the passenger seat was where it ended up. I used the stock 230 battery cable to go to the Chevy starter. I grounded the battery to the passenger seat belt mount. Worked great until it rained.
Then the darn thing would decide not to start at odd times. Gas stations, fast food drive thu's, on trails at the Texas FE and stuff like that.
I cleaned all the contacts at the battery, the cable ends and nothing helped. I swapped out the ignition switch and it helped for a few days, but it still turned over slow. So, I moved the ground to the frame under the cab. Didn't really help much.
I just lived with it. It also started causing the radio memory to cut out everytime I started it. So, I just kept a cd in there and lived with it.
With gas prices the way they are, my Gasser living in my shop and the top being off the M715. I got to where it would only be driven to activites Colton had in the evenings. Cub Scouts and sports practice. Two weeks ago, we got in it for Cub Scouts and it started to turn and then stopped. I was in a hurry, so I just loaded him in the Mini and away we went.
I figured the Optima had died since it is 7 years old. I put in a cheap Walmart battery I used for odd things around the place and it didn't do any better. I figured the starter even though I had swapped out the solenoid a few weeks ago in my hunt for the slow starting problem.
I needed to get it into the shop though to comfortably pull the starter. I made sure the Optima was fully charged and put it in to try and get the thing to start without pulling it. Since I have the Slave attachment leads, the regular positive lead and the frame ground lead all laying next to the battery, I didn't notice until I was putting the Optima back in that I also have the old seat belt mount ground lead there too. I figurd why not? and hooked up all 3 ground wires and both positive leads. The thing fired right up like it used to. Radio doesn't cut out anymore either.
Has ever since too. Even in the rain. I always preach to people to "Check your grounds!" when dealing with MV lights. Seems I need to follow my own advice more. The moral here is that checking your grounds or even adding more grounds to seperate locations is always a good idea if you have electrical problems.
