Results 1 to 4 of 4
Thread: three lever switch
    Default three lever switch
    i tried a quick dirty search, but couldn't turn up an answer. i was thinking that the tree lever switch was common to several MVs. can you guys confirm that for me? thanks in advance
    ryan
    It is. You can find it in little Jeeps, 6X6's, tanks, Hemmits, Hummers, misc tracked vehicles, etc.
    It has been standard for a long time.
    Thanks John.
    the one for the kaiser at work is dead and we are incorperating it into the new build so we have to replace it
    The entire electrical system was designed to be common to all mv's, the design was adopted in 1949 starting w/ the m-38 jeep an added to each new vehicle after that. Most all switches, lights, gauges, generators, regulators (later alternators), all the same as far as mounting an wiring, even wiring code is the same to all vehicles. Excepting m-880's and m1008,1009 these vehicles were relaxed from the standard to keep costs down.
    68 M-715 MVPA #2710
  1. 3 lever light switch
    By TroyWilliam in forum Open Discussion
    Last Post: March 4th, 2010, 09:59 AM
  2. will a 3 lever headlight switch work with 12v
    By Duane in forum Stock Tech
    Last Post: February 21st, 2010, 06:53 PM
  3. Writeup: Rebuildng a 3-lever switch
    By randygar in forum Stock Tech
    Last Post: October 31st, 2009, 07:17 AM
  4. Three lever switch connector
    By Loope in forum Stock Tech
    Last Post: April 21st, 2008, 08:48 PM
  5. 3-lever switch
    By tngreenmachine in forum Stock Tech
    Last Post: October 29th, 2007, 11:58 AM
