So, just don't put the seal joints at the same place as the block "joint'? Offset it a bit? Or rotate it a bit?
Yep, you got it.
Thanks Amphi... that image says everything I was wordily trying to!
You are welcome!
Your explanation is just fine – I just happen to come across the illustration and posted it for a visual reference.
Didn't post the source link because it is for another engine and might have conflicted with your well-described method of removal and installation above.
The image is worth a thousand words...hmmm...I like that line...maybe it'll catch on somehow!
Here's a few views of a 230 that I've torn down recently.
Robert
That is several thousands words there...THANKS HIKER!!
Now we have a great thread on the rear main seal replacement!
OK, much better now. My limited experience was with the seal on the crank shaft but now I see why there are 5 pieces to the 715 kit. Any oil pan gaskets out there?
Gaskets and rear Seal on Ebay. not mine.
Rear seal:
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
Oil Pan gaskets/seals:
http://cgi.ebay.com/ebaymotors/1962-...mZ290137822283
Front timing cover gasket/seal:
http://cgi.ebay.com/ebaymotors/1962-...mZ290137819166
A little pricy but available.
Robert
