I have a little misunderstanding, maybe you can help me on this one ... i'm looking for the good antenna mount whicj is supposed to be a sugar scoop but here's the bug, i think my truck was equipped with a kind of antenna , the mount used only 4 bolts because they is only 4 holes drilled on the right side of the bed but the sugar mount used 6 bolts. May it be possible that i had another antenna mount on the truck ?? or they just bolt 4 of them instesd of 6 ??
Or i may be completely wrong and never had any antenna at all and something else was bolted there instead but those 4 holes are drilled on the upper section of the bed ... if they were drilled much lower i may have think about a jerry can holder ...
i'll try to post a good picture.
