Page 1 of 3 123 LastLast
Results 1 to 10 of 49
Thread: Wheel Cylinder Conversion
    Default Wheel Cylinder Conversion
    Hey Jon, do you want to add this to the Manuals Section?
    Brake Cylinder Conversion to a
    ’93 Ford E350 Cylinder
    Tru Torque W37262 and W37263 available at most auto parts stores
    I know that many of us have done this conversion and fumbled our way thru it.
    I have the privilege of being mechanically inclined by learning from my dad many years ago. Wow… it’s been 34 years now, I sure miss him
    I read most of the postings about this conversion and understood them but thought others might be confused.
    This is not the only way of doing this….your mileage may vary…..
    After jacking up the truck, secure the jack stands (everyone should use jack stands) and remove the tire.
    Remove the three retaining screws. If they are stubborn (which they all are) try using the biggest screwdriver you have. Hit it with a hammer as you try tightening the screw. I know that sounds strange but by tightening the screw it will help break the rust bond.
    Remove the brake drum. You may have to back off the shoes with the starwheel.
    This is what most of us find.
    Inspecting the wheel cylinder you will likely find corrosion. The brakes won’t work if they look like this.
    Remove all the hardware. I also removed the hub because I was also repacking the bearings.
    This is the mounting plate with the new wheel cylinder before elongating the mounting holes.
    This is the mounting plate after elongating the holes. I used a Dremel tool but a round file works just as well.
    The new wheel cylinder mounted
    All the hardware mounted.
    All that is left is reinstalling the drum, applying anti-seize to the retaining screws, adjusting the shoes with the star wheel and bleeding the brakes.
    Until next time,
    Wart Hog
    Good write-up - doing that this week - 3rd truck.
    67 M725 67 M715 68 M715
    May 2008
    Kansas City, MO
    Nice write-up and pics. One thing I found was that the stock brake hose/line fittings didn't screw directly into the new cylinders, I had to have an adapter. The existing fitting was too large for the new cylinder. I used NAPA parts 9025 (left) and 9026 (right) which were referenced in another thread. Not a big deal, but the down-side of putting the adapter fittings in is less space to work. I ended up having to bend the brake line a little to get everything to fit.
    Default Mine fit
    When I did this, the new brake hoses fit the cylinders. I have not heard of them not. Interesting!
    I wonder if you brake lines have been replaced. The wheel cylinders I and many others used did not require any additional connectors. Bolted right up.
    Wart Hog
    Another FANTASTIC job on a tech swap!! I have a set I need to do this too and was gonna do such a write up...if I ever get time...
    SWEET!!!
    I really like the photographs to go along with the explanation. I've read about this modification, but was hesitant due to the required hole enlargement modification. However, after viewing the pictures, it appears to be very a very minor alteration. Thanks for the thread.
    Some other hints for removing the drum retaining screws:
    I gave up on impact hammers, as I always break/twist the bits.
    I lube thoroughly with penetrating oil, then I use a chisel and a hammer to try and turn the screw.
    If that doesn't work on it's own, I take a drill and a 3/8" bit and drill into the center of the screw. After I make a hole approx 3/8" deep, I use the chisel again. By removing the material in the center of the screw, it allows the remainder to flex and a few whacks with the chisel and they turn out.
    Successful 9 out of 9 on this truck.
    My brake lines screwed right in as well.
    May 2008
    Kansas City, MO
    Quote Originally Posted by Wart Hog View Post
    Wart Hog
    Thought about that, but I replaced the left-rear which connects to a hard line that appeared original and I replaced the right-front including an NOS brake hose from Memphis. The NOS hose had the same size fitting as the left-rear hard line (and the original right-front hose) and did not directly fit the NAPA 9026 cylinder.
    Jun 2008
    Booneville Arkansas
    Good write up Joe, even I could understand it.Should have left those dirt dobber nests in there though, gives you more weight on the front axle for mud bogging and such
    Tom
  1. Master Cylinder Conversion - Upgrade
    By Warthog in forum Modified Tech
    Last Post: April 6th, 2021, 09:21 PM
  2. Wheel cylinder ?
    By 93-12smoke in forum Modified Tech
    Last Post: December 1st, 2009, 01:31 AM
  3. stock wheel cylinder
    By Chef in forum Stock Tech
    Last Post: September 30th, 2008, 09:54 AM
  4. Wheel cylinders to Vette master cylinder Q's
    By Nuke_Bill in forum Modified Tech Archives
    Last Post: March 31st, 2004, 10:48 PM
