I need a pic of the drivers side engine compartment that shows the wheel well and frame. If anyone can post one, it would help me alot. TIA.
Wow! I almost couldn't identify any detailing in the photo due to the glare off the brake master cylinder cover.
What have you got attached the the inner fender Binford?
Thanks Tim! I could use a shot showing the Zbar from above. I have finally got my new Zbar set but want to see how much room between the fender and frame I 've got to make a brace to keep it from flexing.
-- Tim Taylor
Tim, the Z-bar is part of the clutch linkage, where the rod from the pedal connects and the force is re-directed backwards to the clutch.
Chris, mine was fairly close iirc. If there's no pic by the time I get home tonight, I'll go take one.
67 M725 67 M715 68 M715
Thanks! The 2nd and 3rd pic is what I was looking for. Basicly, the Zbar I made is VERY close to hitting under the steering column. I need to find a way to hold it in place. To test it, I had put a piece of steel from the end of the Zbar to the top of the shock mount. I figured it was flared out to make it under the wheel well, but wanted to be sure. I guess I will have to make a rod to go from the frame up and then find a way to brace that. Thanks again.
-- Tim Taylor
