Results 1 to 5 of 5
Thread: Aftermarket steering wheel
    Default Aftermarket steering wheel
    I have a Grant on my M715 now. I'd like to mount the original three prong Jeep emblem horn button but will not work on this wheel. Does anyone know a a wheel other than the stock one that is 11 inches or so (like the Grant) that you can mount the stock 1960's three prong button assembly on?
    BTW - the assembly for the OEM is the same as the M715 just chrome with the Jeep emblem.
    Basically THIS:
    Restoration shop is going to cut the center out of mine and make a new wheel for me. That way I'll be able to use the 1967 civi Jeep emblem on a modern 11" wheel.
    Did you get the factory horn button to work?
    Interesting you should ask .. no. Will have to see what Grant has available.
    I tried on mine...to get the horn to work with a grant wheel...never figured it out...hope you do better than me!!
