Forums | Basic Training | Online Maintenance Manuals | The M715 Zone Vin Registry | VPW's M715 Parts List | Galleries | Links |
Open Discussion Open Discussion for all M715 series trucks |
Thread Tools | Display Modes |
We have a retired brush truck for our town that is a M715. Our union owns it, Hasn't ran in a while and they nominated me to get it running again. I got it to turn over and run with starting fluid but it seems the brake master is just toast? I would like to replace with the original but I see some posts with upgrades.
Thoughts? |
Is the vacuum boost shot or the master cylinder?
I just did a upgrade from vacuum to hydroboost on my 69 Wagoneer and am super happy Used this guy. http://www.custompowerbrake.com/ |
Welcome to the Zone.
The fuel system from the sock inside the tank, fuel pump and carb probably all need to be looked at and cleaned up. The stock brake system works very well. Since this isn't your truck. Putting a stock replacement master cylinder on there might be the best route to take. Be warned that you will probably end up doing all 4 wheel cylinders as well.
Remember if you didn't build it you can't call it yours. 6.2 powered M715, 5 M1009's, M416, 2 M101's, 2 M105's, 3 M35's, M1007 6.5 turbo Suburban project called Cowdog. |
If the master cylinder is bad, then the wheel cylinders are probably also corroded. Get new master and wheel cylinders. I would go with the dual reservoir conversion using the corvette master cylinder as it works great without power assist. The original is a single reservoir. If the shoes are good and drums not tore up you can probably get away without having them turned.
The decision to have these drums turned is one that shouldn't be taken lightly given their rarity, IMHO. Most every attempt I've seen made at turning a brake drum has ruined them through incompetence.
#6
I did the corvette master and E350 wheel cylinder, have not had a problem since installed 10 yrs ago.
Thanks for all the help! |
Thread Tools | |
Display Modes | |
