Results 1 to 6 of 6
Thread: oddave715 : Speedo Cable Install
    Default oddave715 : Speedo Cable Install
    Post by oddave715 on Sept 15, 2006, 8:34am
    Anybody have any suggestions or tips on installation? It sure is a tight spot. I'm thinking I may have to remove the parking brake stuff to get to it. Dave
    Default barrman :
    Re: Speedo Cable Install
    Post by barrman on Sept 15, 2006, 8:49am
    I you can use two screw drivers at the same time, it isn't that bad. Getting it off is easy. Going back on is a pain because of the cross thread chances. One screwdriver to turn the nut and the other to keep it straight and or push down. I did mine like 5 times one week replacing broken cables. I removed the stock speedo and put in an Auto Meter. I haven't had to visit that fun spot again.
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Post by teking on Sept 15, 2006, 9:12am
    Well for me ... I removed the cab. That made the changing of the cable EASY EASY EASY!!!!
    Default porkchop :
    Post by porkchop on Sept 15, 2006, 9:28am
    I had my wife do it for me, her hands are a lot smaller.
    Mar 2004
    northern Arizona
    Default compexp :
    Post by compexp on Sept 15, 2006, 9:52am
    I did mine when I still had the xfer case dropped. Still a pain in the butt as I have large hands.
    Jan 2007
    Fort Smith, Arkansas
    Default wrecker :
    Post by wrecker on Sept 15, 2006, 11:21am
    My speedo cable was broken. I got the new one installed with some difficulty but it never would work. To this day, I'm not sure if it ever worked or I had been installing it wrong, or if the cable is incorrect. The speedo gear on my SM 420 was staring me in the face, so after 7 or 8 attempts at the T-case, the tranny hook up was used. BTW, it reads about 10 to 15 mph fast.
  1. oddave715 : cargo cover stops?
    Last Post: November 12th, 2009, 01:20 AM
  2. binfordm715 : Speedo cable lube
    Last Post: November 12th, 2009, 12:20 AM
  3. Speedo Cable
    By Chop Parlor in forum Stock Tech
    Last Post: October 14th, 2008, 10:03 AM
