Results 1 to 3 of 3
Thread: 40grit : Receiver Hitch from RV( pics for Timmah)
    May 2004
    Anchorage, Alaska
    Default 40grit : Receiver Hitch from RV( pics for Timmah)
    Post by 40grit on Jul 8, 2006, 5:41pm
    This is an adjustable hidden hitch designed for RV's. I had to make a little block to compensate for the very rear of the frame, but with 3 5/8" grade 8 bolts on each side, it should drag a house no problem... bolts aren't tight in these pics...need to go buy Gr8 bolts
    And one pic of the little shackles we have laying around work..
    this is one of the smaller ones that was small enough to fit in the pintle...
    Default fredrader :
    Re: Receiver Hitch from RV( pics for Timmah)
    Post by fredrader on Jul 8, 2006, 6:28pm
    Cool,Do you have a part # for the hitch ?
    Default barrman :
    Post by barrman on Jul 8, 2006, 9:58pm
    That shackle is almost small enough to go with Will's snatch block. You know why he needs a square foot of bed floor? Because he never took the block out of the back of his truck. It didn't matter where you were on the trails, if Will hit a bump, that block would bounce and everybody could hear it. I think it broke the lid off one of his coolers it was so small.
    Nice hitch by the way.
  1. fisherman : Receiver Hitch Finishished except paint
    By fisherman in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 08:00 PM
  2. 40grit : Brake line ID w/ progress pics
    By 40Grit in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:26 AM
  3. 40GRIT Hydro-clutch pix
    By MarknessMonster in forum Modified Tech
    Last Post: October 3rd, 2008, 04:19 PM
  4. hitch
    By cnewman425 in forum Open Discussion
    Last Post: February 26th, 2007, 11:57 PM
