Page 39 of 39 FirstFirst ... 2930313233343536373839
Results 381 to 388 of 388
Thread: Canadian build up !!!
  1. #381
    Welcome home Luc. Tech question. What is the distance / clearance between the top of your front Rock and the bottom of your oil pan? I realize you've had axles flipped but may have missed if you added additional lift. The diesel fits with stock flipped springs and a Rockwell correct?
  2. #382
    I like the photo of the 715 in the garage next to the cherokee. Really gives you a point of reference for the size of your truck.
  3. #383
    Jan 2008
    Montreal Canada
    Quote Originally Posted by nolfy View Post
    3 inches exactly between the top rock and the Dodge oil pan. Stock springs but diff under on the front and same in the rear with shackle flip. ( have 3 inches body lift on the cab only to clear the SAE bellhousing and the turbo
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
  4. #384
    Jan 2008
    Montreal Canada
    Quick update ..... snorkel in progress --) need hump silicone boot to finished the install
    Also had to cut the firewall to make place for the 4 inches downpipe.
    Engine with new 160A alternator and rebuilt starter, new auto belt tensioner and waiting for a new center mounted fan hub to install the mechanical fan. Should be installed by the end of the month.
    Then have to find a way to get the water to air intercooler installed .... the unit is big and don't have much space left under the hood
    M104A1 trailer
  5. #385
    Jan 2008
    Montreal Canada
    Quote Originally Posted by m715 View Post
    Good to see things are moving forward
    Well I may have some pictures from the build...
    It was at a time when I was saving lots images from M715 builds for ideas...
    I uploaded what I have, no guarantees they are all from your build, but I think most, if not all should be...if I believe my filing...
    http://cj7jeep.com/m715/kamikaze12volts/
    Hope this helps...
    Thanks ..... only one is not from me . Appreciated that you saved all those pictures.
    M104A1 trailer
  6. #386
    Jan 2008
    Montreal Canada
    Most recent picture in october 2016
    M104A1 trailer
  7. #387
    Nov 2009
    Greenwood, Indiana
    Great looking truck
    Thanks, George
    Joshua 24:15
  8. #388
    Jan 2008
    Montreal Canada
    Been a long time since posting on this forum. Some update on FB if you want to follow. Still some mods to be done ...
    https://www.facebook.com/projetM715
    M104A1 trailer
  1. My Build
    By spgirard30 in forum Modified Tech
    Last Post: February 2nd, 2016, 08:45 AM
  2. my build
    By chadriley5 in forum Modified Tech
    Last Post: January 23rd, 2010, 09:05 PM
  3. #37 build
    By FlatlinesUp in forum Modified Tech
    Last Post: December 13th, 2009, 10:02 PM
  4. Another 4bt build
    By Burritoboi5 in forum Modified Tech
    Last Post: October 6th, 2009, 06:46 PM
  5. Some Build Pics
    By alosix in forum Modified Tech
    Last Post: July 13th, 2007, 03:12 PM
