  #41
Old July 12th, 2017, 12:35 AM
militarypotts's Avatar
militarypotts militarypotts is offline
Sergeant
militarypotts is a Soldier
While I'm threatening to pack it in and just leave the truck sit for a period, the truth is I'll keep searching for the problem. As I said before, as I've gotten older, I've also learned to not get over anxious and get upset. One step at a time. I guess the best thing to do is end this subject until I get it all worked out.
  #42
Old July 12th, 2017, 06:25 AM
JimmieM725's Avatar
JimmieM725 JimmieM725 is offline
JimmieM725 is a Soldier
check your capacitor. power goes thru it to the coil. mine only had 3 strands still connected to it. I soldered a new wire onto mine. the wire from capacitor goes to the coil.
  #43
Old July 12th, 2017, 11:26 AM
Sergeant
Thanks Jimmie, but if I'm correct, a capacitor and a condenser are one in the same, (correct me if I'm wrong please). With that being said, I removed the points and condenser and replaced with the Pertronics ignition system, no points or condenser.
My second supposedly new coil just arrived via U.S. Mail today. When I get a chance I'll install it and see what happens this time. I also need to check the lead coming into the distributor to make sure I'm getting a full 24v. I pray this solves the problem, because I don't know where to go next on this issue. Plus the fine folks on this website by now must be getting tired of listening to me talk about my truck/coil. Thanks again.
  #44
Old July 12th, 2017, 01:20 PM
gonz's Avatar
gonz gonz is offline
Administrator
gonz has disabled reputation
It's like a murder mystery! If they don't want to read about it, they can pass it over. For me, I like reading all the possibilities on how people fix stuff. Personally, I'd like to know what is or is not working.
Come and take it
  #45
Old July 12th, 2017, 05:03 PM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
The ignotor actually has two capacitors. (Condenser was the term used for a capacitor back in the 30s-70s or so. Like changing cycles to hertz, the electronics industry decided to change terms).
One capacitor is part of the power connector. The 24 volt power lead connects to it in the side of the ignitor and that power passes through on its way to the + of the coil (It's used to reduce radio frequency interference). The second capacitor (called the condenser) is connected to the points. It reduces the arc of the points. Tue truck would not run long (if at all) without it because the points would erode away.
So, you actually have two capacitors/condensers. If you look in the parts manual, the pictures show the two capacitors and their locations.
Even with the Pertronix setup, you still have the feed through capacitor because it is the power connector.
  #46
Old July 12th, 2017, 06:02 PM
Sergeant
Thanks Don, my head is now spinning. I received the 2nd new coil today in the mail. I totally removed the distributor cap from the ignitor cover. Inspected it and used a piece of emery cloth on all the contact points, spring, rotor contacts, etc.
As for testing for 24v at the ignitor, the connection in the side is pretty tight. I'll try again, but I don't want to break it. Can I test at the +/- terminals of the coil? Or does it need to be done at the wire lead coming from the ignition switch to the ignitor?
  #47
Old July 12th, 2017, 06:03 PM
Sergeant
I thought I was going to back off on this post, but as long as guys seem to want to help, I'm all in.
  #48
Old July 13th, 2017, 02:03 AM
Don Cavey's Avatar
Staff Sergeant
OK, I am shooting from the hip now because I am in Australia and can't walk out to the garage and look at my truck.
Looking at the -20 Maintenance Manual, Chapter 2, Section 14, Figure 2-35, you should get 24 volts on the left terminal of the coil when the ignition switch is "ON".
That feed through capacitor is contained inside of the power connector, lower right part of the picture.
  #49
Old July 13th, 2017, 05:50 AM
Sergeant
That would make sense to me Don. The only wires coming into the ignitor are the red and black from the ignition switch lead. Also Don, I was wrong when I said that Boycee Equipment distributor cap didn't look correct. I totally forgot that the cap is enclosed and screwed into the ignitor cover. My apologies. I'll go back to work on my truck this weekend I hope. Maybe I'll get lucky and the 2nd new coil will be the answer to my problem. Thanks again.
  #50
Old July 13th, 2017, 06:19 AM
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Quote:
This^
I'm following this thread for the same reason I listen to "Car Talk": it adds to my data base of potential solutions to automotive problems.
It also might help me troubleshoot my !@#$% Cub Cadet...
1998 - 2019
Copyright 1998-2019
