iv got a set of plugs 24 volt for my m715 but carnt cross reff them iv got the following XEJ-8 .. says will eit the m715 they are beep plugs so will they fit my truck> plugs hard to get in england... by the way...
Plugs arent 24 volt...just so you know...
I dont know what "beep" plugs are...is that a brand name or something?
I have found this info from the Champion website:
Stock number 557
Part number XEJ-8
Industrial Plug, 14mm Thread, 9.5mm (3/8") Reach, 13/16" (20.6mm) Hex Size, Gasket Seat, Heat Range 8, Shielded Coil, .025" (0.635mm) Gap, N-678 Replacement Gasket
The stock plugs have these specs:
Thread 14mm
Thread reach 1/2”
Gap .028” to .033”
So the reach on the stock plugs is 1/8th inch longer...gap is a little wider but that can be adjusted. I dont have a cross reference on the heat range offhand.
Seems they are close but not exact. The heat range might kill the idea or make it worthwhile if the heat range is the same as stock.
on looking at the plugs it seems that they are nothing like, the screw thread is shorter. the top part is longer also, so not going to even try them, can any oen get me some plugs for my kaiser please n pm ME WITH COST Il pay pal the cost and shipping.
ta
Mr. August, you are talking about spark plugs, are you not? Six used in the M715. We're a bit confused about what exactly you are requesting. Clarification would help get you what you need.
-- Tim Taylor
Yes i need a set of Spark plugs Fopr my M715 jeep. in england they are a rare motor.
I NEED A FULL SET OF CORRECT SPARK PLUGS,
Im not shouting above.
also need them sending to great briton.
i have pay pal...
Try John at Midwest Military I'm sure he ships outside of the states.
DavsJ
