Forums | Basic Training | Online Maintenance Manuals | The M715 Zone Vin Registry | VPW's M715 Parts List | Galleries | Links |
Stock Tech Tech forums for Stock M715 series vehicles |
Thread Tools | Display Modes |
#1
I finally dipped into my wallet for a new gas filler neck before the old one turns to crumbles. I've only been putting it off 9 years now....
Before I go to do the swap--are there any things that tend to bite or tips/tricks to save hassles? Everything looks obvious...but tight clearances and fit might make the change a bit fiddly. I figured it was better to ask a silly sounding question before I dug in and had issues than battle something there was an easy procedure to accomplish if you knew the "trick". Hopefully the answer is "Goes right in, slick as snot". Thanks |
#2
Warm it up with a heat gun to make it more pliable and a squirt of silicone spray would not hurt either.
#3
Replace the vent line end rubber if you unbolt the filler neck from the bed to do the hose swap. I did not replace my then 48 year old rubber piece when I change out my hose in 2015. I am using the vent line as the diesel return line. It swelled up and turned off my engine. Took forever to figure it out too.
__________________
Remember if you didn't build it you can't call it yours. 6.2 powered M715, 5 M1009's, M416, 2 M101's, 2 M105's, 3 M35's, M1007 6.5 turbo Suburban project called Cowdog. |
#4
Dish soap works nicely for fitting rubber parts like this. Also, setting the filler hose out in the midday sun to soften it up can be helpful.
Thread Tools | |
Display Modes | |
